Yamaha 60C 2strk 1999 Heat Alarm
Ted2h
When moving at slowest speed, motor has a trickle of water and overheats. Have replaced water pump kit, tested thermastate - looks OK, Motor runs great at higher RPM with good water stream. Any help will be appreciated.
rodbolt
Re: Yamaha 60C 2strk 1999 Heat Alarm
make sure its idling at the correct speed and the pressure control valve is clean and in good shape.
Ted2h
Originally posted by rodbolt:<br /> make sure its idling at the correct speed and the pressure control valve is clean and in good shape.
Ted2h
Thanks Rodbolt, I will check your suggestions a let you know results.
