I have tried on my YAMAHA 8HP 1989 ( LONG SHAFT )to get the LOWER UNIT OFF...
After having removed all 4 bolts I can only seperate the lower unit from the rest of the leg by an inch and a half. When I try to pul it ..it causes the gear leaver to move back and forth.... Ray Neudecker kindly replied mentioning that I must disconnect the SHIFT SHAFT. <br />I WOULD APPRECIATE INSTRUCTIONS ON HOW I SHOULD LOCATE AND DISCONNECT IT. I can only see a bit of it and cant see where to undo it. Thanks Mike
