Yamaha F200betx idle speed problem
Mbache
Hi fellow boaters
Recently my Yamaha F200betx 2013 V6 fuel injected outboard engine
has started to stall at idle speed. Im quite sure the problem is not related to poor fuel or supply issues as the engine performs flawless at higher revs. From what i can research the problem could very well be the idle speed controll valve, however im not able to locate the valve anywhere on the engine nor on Yamahas online parts finder its to be found in the drawings and descriptions of the specific engine serial number. My question is now does this particular model not have such a valve and if not how do I adjust the idle speed?
In hope of positive help.
Michael.
dingbat
Hi fellow boaters
Michael.
Guessing…might be what you’re looking for.
No function description, but looks like your typical throttle position sensor in its typical location
Sensor Assembly 68F-83688-10-00
Mbache
Hi dingbat
Thanks will check the sensor!
