kathys1guy
- Feb 19, 2006
- 11
Hi All;
I have been researching this one for a while. A few months ago, after running a load of family up the lake at cruise speed, when I went to reduce the power to idle, it stayed around 2000 RPM. After restarting, the idle returned to normal. It started up with no problem and it did not occur for a period of time after that. Since then I did routine maintenance which included oil/filter change, lower end lube change, and new NGK LFR5AIX-11 Iridium plugs gapped to .040 (.040-.044 normal). They were the original plugs, standard NGKs LFR5A-11 and were very clean with about 330 hours on them. On the test run after maintenance, it started right up, idled smooth when cold, accelerated nicely ran at high cruise (5000 rpm), reduced power to idle, now it delayed at 2000+ RPM then drifted to about 1500 and fell off to 1000 RPM, now running rough like 1 cylinder was not firing. Back 2 the shop (my home), filled the half tank of fuel to full with mid-grade and to cans of Sea Foam engine and fuel system cleaner and installed a fuel/water seperator. Rechecked plugs and test ran again...same results. Upon securing boat at home , noticed primer bulb was leaking...replaced, same results. Now thinking plug issues...reinstalled original set of plugs cleaned and gapped to .040, test ran...same reults. With the Computerized igniton and fuel injection, I am just about ready to give up and send it into the Yamaha dealer. By the way, at their direction, I did empty out the canister from the fuel/water seperator and it appeared clean...HELP...Please! Thanks in advance
