Motor Starts right up idles fine for 3 minutes then you try to put it in gear and it dies then you have to to turn the throttle as far as it will go in the cranking postion to restart have to do this several time before you can get it to run down the lake then once it is running it runs fine until you get it up past half throttle the it starts cutting out you can feel the motor jerk a little. Then you can put it to full and it will smooth out some. Need some help please any expertise.
