I have a 2003 200 hp hpdi yamaha motor recently after cruiseing for a 1/2 hr or more the motor would hiccup then resume normal speed however after slowing down to say trolling speed the motor would run ok for a few minutes then start to hiccup a few times then stall out like im out of fuel . the primer bulb would be like sunken in after massaging the primer bulb to pump a little fuel the motor it would start back up again for a few minutes then stall all over again. this is the second time this has happened to me the first time after getting back to the dock I had changed the fuel seperator filter and all was ok for a few trips then it started up again , this time I changed the fuel seperator filter again although it was only about a month old I emptied the fuel filter and it did have a little grit in it but i don't believe it was enough to actually clog the filter and starve the motor any Idea's ?
thank you
thank you
