Yamaha lower unit Problems
cm4graphics
I have a 2001 150 v-max motor, I went out today and the motor worked great until 15 min into my trip and it popped out of gear. kinda like I spun the prop. It would only idle for a while and then work again in gear, later it would do it again, any solutions to fix the problem? Any help would be appreciated. Matt
JUSTINTIME
Re: Yamaha lower unit Problems
either miss adjusted shift cable or a worn clutch dog
Ray Neudecker
A bent shifter pin can also cause this problem. First be sure the cables are adjusted properly.
