Broke off part of skeg on 1997 Yamaha 150 Pro-V. Found prop shop that will weld on new skeg. They want me to bring in lower unit. What is required to remove the lower unit besides removing the four bolts? What gear should the motor be in to remove? Anything to watch out for in removal or during re-install? Would you recommend replacing the water pump while it is off?
