I have a 1995 115hp. I have removed the main tilt pin holding the tilt piston to the powerhead, the six 14mm bolts and the two 17mm short bolts and disconnected the electricla wires. The trim unit wiggles but won't come out...part of the problem may be that I am trying to remove this unit while the boat is in the water!<br /><br />any help, drawings, suggestions?<br /><br />I'm removing it because it appears that all of the fluid has leaked out.
