ShaneCarroll
- Feb 10, 2009
- 639
Re: Yet Another Problem: Stuck In Neutral?? Pics Added
To be specific on the last service of the outdrive: In March I drained and refilled the lower unit oil while I changed the impeller. I noticed it developed a slow leak when I took the outdrive off to do the gimbal bearing about six weeks ago. I set it on the spare tire on the trailer and left it there for a few weeks while I was working on the gimbal and stuff. Upon retrieving it, I noticed the oil sitting on the rim of the tire. I refilled it prior to first use, but I did not have the pump thing, so I used the top screw. It all goes in the same place, doesn't it? Anyways, I filled it to the very top with oil, and proceeded to take it out four or five times after the gimbal bearing job. I guess it leaked out and caused the damage?
I just want to know where it is bad, so I can know for future reference. Do I need an entire outdrive or just the upper unit? Thank you.
