I wanted fresh upholstery for the upcoming season. So I ripped the carpet and seats out of my boat only to find out my floor is rotten. After some more digging, it turns out the stringers are also rotten and falling apart.
Stringers issue:
I am wondering if I can use the 2X4s I've had in the basement for over a year. The 2X4s are dry and I would cover them in fiberglass resin before installing them in the boat. Does that sound like a good solution?
Transom issue:
The transom is also in very very bad shape. As you can see in one of the pictures, the fiberglass cracked and the crack is a good 12" long. The wood that sits behind the fiberglass is also rotten and falling appart. I have no idea how to get to it since there is a "pit" right in front of it. How should I tackle that job?
And expansion foam... Can the HomeDepot type foam be used or do I need to buy something fancy and pricey?
Stringers issue:
Transom issue:
