I have read alot of threads of people with temp alarms going off "constantly" and some temp alarms not going off at all.. Here is what happened to us today FIRST TIME OUT THIS SEASON...
Let motor warm for about 5 minutes. Visual Pee stream from outboard. Running about 5500 rpm for about 5 minutes when the alarm sounded & rpms dropped to around 1500... pee stream still present. Shut off motor. Restarted fine, ran on low rmps (going back to ramp) when temp alarm sounded again.. Shut off motor, restarted after a couple of minutes.. Ran about 4000 rpms back to marina ( a few minutes- STILL ran great).. decided to head back to ramp.. All was fine , then it happened again at low rpms)..
So, the alarm sounds on high rpms AND at low rpm, ONLY after running a 3-5 minutes..
History: Bought used in late fall. Only taken it out twice. NO alarm issues. Over the winter, I changed the injection oil from Quick Silver to the Optimax synthetic (per dealer recomendation).. Winter gas has stabil AND seafoam in it. (yeah, I know).. I have NOT changed the plugs.
The boat starts right up first time everytime. No smoke, sounds smooth,fairly quiet, 5500 RPM , 32 gallons of gas, full loading two people all the junk. Heavy chop water with occasional white caps. Water 50 degrees.
Any suggestions where I should start.
Replace impeller? I dont know how old this one is.
Replace plugs ? Could they be laboring to burn of the crap?
Thanks for the help,
Billfo
Billfo
