It could. Did you check the advance to see if it was working?
You need a timing light that is advance capable .....no vacuum advance--it's mechancial
Sure it will run, but if those #'s are truly 80 on a V-6, it will affect performance quite a bit.....
No that ain't the way......when we checked compression, we did it with the engine running taking a plug out at a time. Is that an accurate way to do it, or do I need to remove all the plugs and turn the engine manually? Wouldn't I get a higher read on the gauge with the engine running? (sorry if it's a stupid ? I've never done one before!)
Ground the coil by removing the lead to the distributer & ground it to the block......
Remove a plug, put in the gauge & turn the engine over at least three times with the starter.....
Take your reading, & write it down....
Repeat for all six.....
Of course the test should be performed on a warm engine....
If you get a low reading on a cylinder, add 1 oz oil & do it again....
If it increases significantly, then you have worn rings....
If not, you have a valve issue....![]()
I never did it the way you descibe, so I don't know.....So the way I did it would give a false reading?
I never did it the way you descibe, so I don't know.....![]()
Who's engine do you have? Merc, Omc, Volvo, OTHER??????????
How to do a PROPER compression test.
http://www.boatfix.com/merc/Bullet/97/97_25.pdf
PS, when an engine is running, the compression is lower than when cranking.
Just curious, how much lower is it ? ( A little, a lot?)
Check it the proper way, then you will know exactly how much difference there is.
