Re: 115 evinrude motor starting problems
You asked a simple question to which there is no simple answer since all you talked about was the little red knob that you knew nothing about. That was explained and I suppose we we could have just guessed at what your starting procedure was which would have resulted in many back and forth responses which is like pulling teeth. If we have information up front rather "my engine won't start" we save a bunch of time. I merely explained what works along with a little historical data. A polite response of "yup, that's the way I do it but it still won't start" would have been welcomed. Stating things like: this has been getting worse for some time, tune up done on xx/xx/xx, compression is ok, spark is ok. Fuel is about 3 months old would be meaningful data. I don't get chased away easily so give us something to go on.
