- Jul 23, 2011
- 51,971
| Rogue 2420 hit-list | |
| Run Steering cable (new cable on order) | Fix folding seat bottom |
| Mount Steering actuator | mount seat base doors |
| Secure fuel tank | make new side panels |
| touch-up gel in bilge - !@#$!@#$ | upholster side panels |
| Pull pitot tube hose for water pressure gauge | install side panels |
| Plumb cooler drains | make new aft seat back |
| Mount cooler lids | install exhaust h-pipe |
| Fix cooler lid – order new latch handles | modify exhaust y-pipe |
| Install deck covers | mock-up captains call |
| Wire step lights | Modify captains call diverter outlet for custom H-pipe |
| Install underwater lights | wire captains call |
| Wire underwater lights | mount exit tips |
| Install courtesy lights | install mufflers |
| Wire courtesy lights | paint outdrive |
| Drill seat base mounting holes | paint interior kick panels |
| Mount seat bases | assemble outdrive |
| Install fender cleats | install outdrive |
| Install fuel pump | install bilge pump |
| Mount oil filters | install bilge thru-hull |
| Plumb in oil filter temp switch | plumb bilge pump |
| Make tee-fitting for water pressure | install wing-window seals |
| mount anchor holder | install wing window latches |
| new bow anchor line | run-wires for all-around light |
| modify horn | |
| install horn | |
| buy radar arch | wire bow light |
| modify radar arch | wire dock lights |
| paint radar arch | make dock light covers |
| make radar arch brackets | |
| Cabin interior….. TBD | |
Tan one looks like he is serious lol must be the captain of that land ship!
