1988 Rogue 2420
a bit of progress.
this folks is a 30% chance of rain in Florida.... everywhere else, 30% is a probability. in Florida, its the percentage of your property being rained on.
Motor dropped in
Andrey taking drone footage of me adjusting mounts, and aligning
job done
so I have about 50 items on the hit-list....
some would only take about 20 minutes without the engine in place..... and with swearing and contorting..... about 8 hours.
didnt have access to the crane this past weekend or the motor would have come back out.
however..... gratuitous side shot
modifications of the purchased spring-loaded bumper cleats.... the e-clip is bigger than the hole the cleat mounts in. so I am having the end of the mushroom drilled and tapped so I can use a screw and washer. will then add a drain line down to the bilge as they do leak a bit.
installed the step lights. using a 9 volt battery for now to make sure wiring is good to go.
coming along one item at a time on the check list
Rogue 2420 hit-list
Run Steering cable (new cable on order)Fix folding seat bottom
Mount Steering actuatormount seat base doors
Secure fuel tankmake new side panels
touch-up gel in bilge - !@#$!@#$upholster side panels
Pull pitot tube hose for water pressure gaugeinstall side panels
Plumb cooler drainsmake new aft seat back
Mount cooler lidsinstall exhaust h-pipe
Fix cooler lid – order new latch handlesmodify exhaust y-pipe
Install deck coversmock-up captains call
Wire step lightsModify captains call diverter outlet for custom H-pipe
Install underwater lightswire captains call
Wire underwater lightsmount exit tips
Install courtesy lightsinstall mufflers
Wire courtesy lightspaint outdrive
Drill seat base mounting holespaint interior kick panels
Mount seat basesassemble outdrive
Install fender cleatsinstall outdrive
Install fuel pumpinstall bilge pump
Mount oil filtersinstall bilge thru-hull
Plumb in oil filter temp switchplumb bilge pump
Make tee-fitting for water pressureinstall wing-window seals
mount anchor holderinstall wing window latches
new bow anchor linerun-wires for all-around light
modify horn
install horn
buy radar archwire bow light
modify radar archwire dock lights
paint radar archmake dock light covers
make radar arch brackets
Cabin interior….. TBD
and every afternoon it starts raining at about 4pm until about 9pm. I leave work at 5.... my yard is too wet to walk to where the boat is sinking into it in order to work on the list.
Finally able to get some semblance of work on the boat today
Bow light wired and mounted
Deck hawse mounted
Anchor brackets mounted
Fuel tank hold down brackets installed (and i got stuck in the bilge doing so)
mounted the bilge pump base
Cleaned a plethora of parts
wire brushed old sealant off a bunch of hardware
Painted the all around light pole
Spent hours going thru boxes
Mother Nature does not want this boat finished.....
now I have to spend boat workin' time this coming weekend as weather prepin' time
However it sure beats shovelin' snow and winterizin' boats
2 hour projects will turn into a 3-day ordeal when you damage/bend/break/wreck a bolt
stripped out the threads on the v-band clamp on the exhaust...... in frustration, taking the dogs to the dog park for a walk....
So in addition to the boat, Tammy has the pool being redone
Stripped bolt
Here is us going shopping. Dogs needed help crossing the parking lot in the 95 degree heat
mickyryan
Tan one looks like he is serious lol must be the captain of that land ship!
mickyryan
Well samantha running a tight cart she is like errybody paws inside the cart and dont exit until the hoomin comes to a complete stop... i aint playin with you two today! Lol
back to working on the boat...... spent most of the day scrubbing lizard **** off the boat. damn things had a poop-a-palloza fest on the foredeck. spend 3 hours scrubbing the non-skid, then needed bleach to remove the poop stains
cleaned out the cockpit and bilge too. 2 months of rain, dust, and damp weather did its job..... spent a total of 6 hours scrubbing.
then the wind took the 10 x 20 canopy for a ride. Wife says dogs barked and it was gone. had to pull it out of the neighbors sugar magnolia trees. then pull it apart, flip it over, duct tape the rips, and re-assemble.
finally got the foredeck non-skid waxed.
for every 3 items on the list I knock off, another 2 get added... at least I am gaining ground
