Greetings!
During the winter I acquired a Lowrance HDS7 package with the StructureScan module. The warming temperatures elevated my boating itch, and after de-winterizing the boat this weekend -- I'm getting ready to install the system.
My first struggle is mounting the transducers: the Skimmer which comes with the HDS7 and the (long...) LSS-2 of the StructureScan. In the last few months I spent hours reading forums and watching online videos trying to get ready for actually mounting the transducers and other components. Following are some guideline instructions that I'm trying to follow (also pointing out conflicting information I found in forums/videos):
1. Unless I want to track with the StructureScan at planing speeds (which I don't) -- I can mount the LSS-2 transducer above the level where it's flush with the bottom of the hull; in other words - it will be in the water only at low speed, and out of the water at planing speeds. Lowrance recommends that setup as it helps protecting the sensor and reduces drag.
2. Most online information I found calls for installation on the starboard side; Lowrance makes no such distinction, and both port and starboard side are equally good. On my boat installation room is tight (as pictures show below), I already have the speed sensor mounted on the starboard side of the outdrive, so I prefer to mount on the port side.
3. Some online information make the point of installing the Skimmer transducer so it's above the LSS-2 transducer (so it's out of the scanning view of the LSS-2). Lowrance makes no such requirement. Is that a real concern? Anyone knows the field of view of the LSS-2? Lowrance says that the two transducers should be within 12" of each other, so I can't really mount them one on the port side of the outdrive and the other on the starboard side. Also, the LSS-2 is very long (about 10"), so if I mount it too close to the outdrive it will get whacked on tight turns; and given the Vee of the hull -- if the Skimmer is close to the drive and the LSS-2 is further out - it will put it even higher above the Skimmer...
4. Lowrance specifically says NOT to mount the LSS-2 at the bottom of the hull.
5. On my boat the drive is on a "recessed transom" with two "pods" protruding back on either side (the stainless rods in the image are supports for the swim platform); I'm afraid to put the transducers all the way on the back of these pods because I *know* that sooner or later they'll get whacked or whack someone (swimming when moored, etc.)
What do you think? How would you go about mounting these transducers?
BTW: If there's a good place you can refer me to with concise information on procedures and specific materials/sealers I should get (e.g., simply drill, fill the hole with 3M-5200 and mount the screw?)
Your help and advice is much appreciated!
Zevi.
Zevi.
