1997 Chaparral 2330 Bowrider - Minor Restore and Refit
Woodonglass
I think it's time for one of these...
NorthwestChap
A few years ago, ******** was closing out their rebranded Scotty rod holders in white. I snagged 4 of each style with mounts. We installed the 8 mounts around the boat.
NorthwestChap
Had to do a little trimming to fit over the transom tie down U bolts. Also, had the manufacturer send out a couple more support rods to fit with the trim tabs I planned to install.
NorthwestChap
Still need to get caught up on the rest of the installation and improvements. So, after lining up and fitting the swimstep, and getting the new supports, I was able to mount the swimstep with the exception of the support tubes. I still needed to install the trim tabs to make sure the support tubes did not interfere with the actuators. Unfortunately, the transom has a slight curve on the bottom where I was installing the trim tabs.
NorthwestChap
With the backers eliminating the curve, the trim hinges moved without binding. Finished installing the trim tabs and swimstep support tubes.
