Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
A few years ago, ******** was closing out their rebranded Scotty rod holders in white. I snagged 4 of each style with mounts. We installed the 8 mounts around the boat.
Had to do a little trimming to fit over the transom tie down U bolts. Also, had the manufacturer send out a couple more support rods to fit with the trim tabs I planned to install.
Still need to get caught up on the rest of the installation and improvements. So, after lining up and fitting the swimstep, and getting the new supports, I was able to mount the swimstep with the exception of the support tubes. I still needed to install the trim tabs to make sure the support tubes did not interfere with the actuators. Unfortunately, the transom has a slight curve on the bottom where I was installing the trim tabs.
