update: spent all weekend working on the engine :faint2:
new distributer was different from OE so i hadda ditch the pertonix set up. on a positive note, the new distributer starts strong and fast. also had to ditch the flame thower II coil it was making my number 1 plug drop out, plus coil got super duper hot!:mad2: good thing i caught it in time and swapped it for the old cool coil
. luckily i left my resistor wire in tackt so the swap back was fairly easy except for cutting away the mile of electrical tape i wrapped around the loom of wires on the side of the rocker arm cover.
ound:
the new carb is going back, i did everything i could to try to make it work, that sierra carb is a polished turd!!! this is my second one.... but then again.... fool me once shame on you, fool me twice shame on........ my neighbor LOL
eep: :doh:
i put the new float in the old carb that i passed on installing when i did the rebuild becasue of the missing registration marks, but now i figured out exatcly where the tow is so im pretty confident with my measurements and adjustments of the new float
timing is set at 12 btdc and idle is around 1000, im going to put it in that water and bump down the timing to as close as 4btdc as i can get it or till smooth whatever comes first, then tweak the carb a lil, then go for a test run, if there is still no top end ill cross that bride when i get there, seems fine on the trailer tho
just thinking, if there is still no top end wont be the distributer so will have to be carb. at that point ill have the shop rebuild the carb along with my pride!:eyebrows::yo:
i spent so much time on that rebuild i just knew i hit a home run... i guess well find out on the next test run
:bolt:
my snards came but i was so bizzy with the motor i didnt even open the box, ill ckeck them out 2maro and post some pix
oh and my rocker arm cover is still leaking, noticed that some of my bolts had backed off so i retightend and wiped up any visable oil from the bilge and top of the motor... wasnt alot but still too much for me!
scott says he doent like the cork style gaskets, i havent been able to find a rubber style gasket yet if anybody knows where to order from please let me know
persistent leak could have been me not snuggin up the bolts enough:noidea:
