Keeganh
- Jun 16, 2014
- 21
HELP!! I'm new to this forum so I will try and be as descriptive as possible with my limited boating vocabulary, I recently purchased my first boat, a 1974 volvo penta 270 with a 130 horse b20 engine, the boat will idle and accelerated perfect in neutral, and if drive is engaged on hose, once the engine is in the water and under load it will not go over 2,000 rpm... It just Boggs out and stays there, I have replaced fuel, fuel pump, cleaned fuel lines to carb and ran direct from a hose to fuel pump to eliminate any fuel line issues, I have replaced points, rotor, coil, plugs(twice) plug wires, I took off the fire suppression cover and did a full spray of the top of the carbs with sea foam, I'm in the process now of completely tearing apart carbs and cleaning them, I'm at a loss and don't know what to do, there is no exhaust flapper but I was told this would not cause my problem, there is no smoke from exhause, engine is not over heating, gauges all read perfect.
