Could you just slide the extra stringer/cleat further down the slope of the hull . Keep it parallel with the original ...
Cut the bottom to conform with the hull ...
It's tough to tell from the pic but the angle changes at the end of the outside stringer and the slope increases too. Not sure how I would glass a cleat in that would help for more than a few inches. I think if I put a couple bulkheads on the outside too , the strength should be there. Thanks for the feedback Woodonglass !
That's the thing, it's only exposed on the sides not the top. Can I sneak a new section under the plywood? Good advice on the cleat info up front. Thanks
