Ihateclevernames
- Sep 6, 2015
- 67
Well, went and looked at the motor today.
it is a 1977 Evinrude. Model number 35653C
All of the parts were in the correct places based on what I can tell from looking at diagrams and talking with you guys this last week............and of course............tearing mine apart.
The reason they couldn't find the model number it that there was a piece of wood on the motor stand blocking it, and neither the owner or the shop owner knew where to find it.
A little bit more on the shop owner being somewhat clueless.
It is a prop shop that specializes in the revival or props and installation of lower unit components. The motor had been up there for a few weeks and another mechanic who was working there previously knew more about it versus the shop owner. The mechanic was since let go due to personal issues. So that makes me feel a little bit better that it wasn't a case of the shop owner being a tool.............it was that he just really didn't have a great deal of experience with engines.
So, starting out........the motor looked as it was pictured. In pretty good shape for almost a 40 year old motor. Needs a new prop (luckily it is located at a prop shop). So we started out by staring it after hooking it up and watching the owner zap himself with the ignition in his hand and not paying attention..........haha. Motor cranked up as it should when using the choke and them moved to an idle. Sounded a little high at first then it settled down.
After seeing that it started, we checked the compression with a brand new compression gauge and it registered between 115 and 120 on both cylinders (closer to 120). So that is good. The compression was checked generally cold as we did not have the tub set up yet. Would you suggest checking it again after it is warmed up? From what I have seen, it appears that 120 is pretty darn good, especially if they are close.
The mechanic previously replaced the fuel lines
Replaced wiring that was brittle due to age
Replaced the spark plugs (NGKs)
Cleaned the carburetor
Replaced the starter solenoid
Replaced the water cover gasket (It was previously leaking water at the bridge between the spark plugs)
The shop has documentation that all of this was done as well, and the things looked as the should be. Gaps were correct, Solenoid checked out, Carb was generally clean with new hardware. Lower unit oil was dark and generally looked free of any milky substance or pea soup like gear oil. Neither party knew the last time that the gear oil was changed. Same goes for the water pump. Granted the engine has not been ran very often in the last 2 years (so im told). However the water was flowing very well from the exit point on the shaft and from the pee hole as well. I was actually surprised that it worked so well for neither of them knowing the last time that it was changed.
Checked on the controls as well and everything looks like it will be plug and play with what I have on the boat from the Johnson that was on there.
After allowing it to warm up a little bit more, I noticed that a small amount of water starting to come out of the bridge point on the head cover from the water cover gasket. The water started to increase a bit, so we shut it off. After inspecting where it came from, I checked the bolts and noticed that I was able to unscrew one of the bolts by hand. Checked the rest and they were generally all loose. It appears that the guy that was previously working on it didn't torque them to specification, which may have allowed water to penetrate the interior of the water cover gasket and ruin it. So we pulled the cover off to inspect the water cover gasket and basically the gasket was pretty soggy.
This was the only issue that I was able to find and needless to say, as much as i would have loved to just get it and attempt to work on it.............I help off and told him that that issue needs to be fixed before we proceed, along with the prop.
He is going to have the guy that runs the prop shop replace the gasket and prop this week (he may not know much about outboards, but replacing the gasket and 8-10 bolts is pretty straight forward). If those things get fixed this week we are going to meet at the river (so I don't have to drive 2 hours in order to meet him) and install the motor on my boat and take it for a spin prior to payment.
The price would still be $475 for the motor with him being responsible for fixing what is currently broken.
Thoughts? To me, this doesn't sound like a huge issue pending it was just a gasket issue.
I can always walk away from it, but was actually happy with what I saw. I really found myself doing all of the things that I should have been doing on the last motor that burned up on me. Unhooking things, opening things, testing things. I actually felt pretty comfortable checking things out as it is almost identical to my 81 Johnson.
Is there any way to check anything else out further? Maybe a way to test the coils or anything else?
Thanks!
Thanks!
