I have an issue with my outboard not reaching wot rpm range. I recently completely rebuilt the motor had it bored 60 over, put forged pistons in it. I replaced all electrical parts including power packs, coils and all. The current prop has some dings and bends in the leading edges of the blade and appears to be the original installed prop.
The motor is a 1987 OMC Seadrift Drive 1.6l (Johnson 115 motor). 2.0 gear ratio.
WOT range is 4500 to 5500. From what I can find, 5100 is perfect.
Boat is a 1987 Glass master 18' CC. (No idea on weight.)
Current prop is a Johnson 13.75x15 Stainless Steel prop.
I have a hydrofoil installed.
I checked the prop shafts and it's straight as it gets. I'm only getting about 4000 to 4200 rpms out of the motor and topping out at about 28mph according to my GPS and the boat is slow to plane. . Could the bent blades and such be causing my issue or do I just need a 13 pitch prop? Im going to order a new prop but need to know if you guys think 13 pitch is too low for this boat? Also what should my max speed be on this rig? Bought the boat used and don't have any manuals or anything for it.
