No Title
A bit of progress....then a step back....then a bit more progress
found a creative piston stop to find dead center
degreed in the cam, required borrowing a set of dial indicator points from the machinists at work
had the heads on the motor just before Irma, just about to fire up the torque wrench and I realized I did not swap the valve springs that match the cam.
so....pull heads apart, start to swap the springs and realize the umbrella seals wont fit with the dual springs I have.
off to the machine shop to get the guides cut for positive seals.
get heads back just before the hurricane, just in time to wrap in plastic and hope the house was still standing
then a trip to Wisconsin so sell my Supercharged Northstar powered Opel GT project and clean out storage
fast forward until this past weekend.
received new damper plate, new SFI flywheel and shims to finish the heads
measure installation height on the springs, shim to exact install height of 1.900" +/- 0.003
Get heads bolted on
get motor painted wrinkle red
get oil pan on
now, for the valve covers and intake.....polished or painted wrinkle black.
