BBC build- Don't tell the Admiral
not to mention the 9-10 weeks became 5 months. going to see if I can get a discount
Just picked up the block and heads.....pictures to follow
Lost all the pics from yesterday....
Outdrive fully disassembled and plasted, ready for paint
Block on stand. Measured main and rod clearances. 0.002 on mains, just under .002 for the rods (running coated bearings).
Took everything back apart to bore notch the cylinders
alldodge
No expert as you know, but .002 on clearances I would be worried about with a high volume oil pump
talked to Johny at Yows, and that should be fine. spec is .0020-.0025 motor is capable of high RPM's. the only thing keeping the RPM's below 6300 is the cam and carb peter out.
here are some pics that I took today
0625171809a_zpszmbz08s3.jpg 0625171809d_zps6kmdgmfg.jpg 0625171809c_zpsmudusvun.jpg 0625171809b_zps7a1jdhai.jpg 0625171840_zpsknqspzlg.jpg 0625171839_zpsbmhafwpr.jpg
Outdrive is painted....some assembly required
ok, so attaching from the phone didnt work.
fetch
Tail_Gunner
Been away for a while life has brought many changes and good one's. Looks like things are evolving nicely here to,I really like what you've done. That engine should brighten your experience just a smidge so to speak. With that being said great work im a tad envious.
Thanks Tail_Gunner.
its been raining every day since I got back from vacation. couple that with grass that was 2' tall and I havent touched anything in the past 2 weeks other than fix the pics
however the admirals car will have to go outside as I want to measure cylinder bore and pistons tonight to verify the fit prior to bore notching and bolting it together.
So, finally getting back to the project
swapped use of some tools with a co-worker. he needed my spring compressor and degree wheel, i needed his bore gauge.
First, dig out the motor
then dig out the measuring tools
then start at cylinder #1, check the bore at the top, middle, bottom, and in both directions
0713172017.jpg 0713172012.jpg 0713172019a.jpg 0713172010a.jpg 0713172015.jpg 0713172020.jpg 0713172019b.jpg
overall the bores are good, total taper top to bottom is .0008" on one cylinder.
total out of round on one cylinder is .0006"
not bad for a production block.
cylinder bore is 4.310
piston to wall clearance is .005
now to mask off and notch the bores
overall the bores are good, total taper top to bottom is .0008" on one cylinder, most about .0005
total out of round on one cylinder is .0006", most .0003
not bad for a thin-wall production block.
No Title
Been a while, need to get back to this.
been doing some interior work (see link in signature) in between working on the motor and other projects.
had to do a timing belt kit for Zack's car as he heads back to college Thursday. had to wait a week for the cam sensor to come in @#$%@#$ brittle plastic
yeah, no room in the dang car
trip to dollar store for modeling clay ....
core plug installed.
bore notching
slathering the cam full of assembly lube and motor oil. like trying to hold onto a snag fish.
crank in and torqued down.
gap filed the rings yesterday (will post pics a bit later)
today, started assembling pistons, installed one of the connecting rods backwards :facepalm: had to chase a spiral loc down the driveway :facepalm:
a good mechanic can identify automotive chemicals by taste. assembly lube and brake cleaner.....yum..... a bit of blow back from cleaning a rod
went to wash out the taste, realized im out of beer. :grumpy:
done for today
No Title
So, here are some pics
my setup for filing rings.....not fancy..... time consuming....mind numbingly time consuming
top rings gaped to .022, 2nd rings gaped to .024, oil rings gaped to .016
Good call, we all need to know our limitations :D
today's motor building shirt (something dad picked up last time he was at the flea market - Not really my style however fitting for the conversation.)
and yes..... picked up more beer....
No Title
A bit of progress....then a step back....then a bit more progress
found a creative piston stop to find dead center
degreed in the cam, required borrowing a set of dial indicator points from the machinists at work
had the heads on the motor just before Irma, just about to fire up the torque wrench and I realized I did not swap the valve springs that match the cam.
so....pull heads apart, start to swap the springs and realize the umbrella seals wont fit with the dual springs I have.
off to the machine shop to get the guides cut for positive seals.
get heads back just before the hurricane, just in time to wrap in plastic and hope the house was still standing
then a trip to Wisconsin so sell my Supercharged Northstar powered Opel GT project and clean out storage
fast forward until this past weekend.
received new damper plate, new SFI flywheel and shims to finish the heads
measure installation height on the springs, shim to exact install height of 1.900" +/- 0.003
Get heads bolted on
get motor painted wrinkle red
get oil pan on
now, for the valve covers and intake.....polished or painted wrinkle black.
No Title
More pics
Shimming the head
Heads installed, rockers installed and adjusted.
Motor masked and primered
Wrinkle paint installed
alldodge
Coming along very nice. Guess the wrinkle paint makes it look like a painted rusty motor
LOL...I applied it a bit thick, more texture than I like....however live and learn........
