40 yahama getting water on spark plugs
tr-21
changed head gasket on motor but its still getting water on plugs any ideas thanks
robert graham
Did you check/resurface the head for being warped when you removed it for gasket replacement?....
robert graham
If it's warped then you can lay a sheet on Emory paper on a good solid flat surface and using a figure 8 pattern using your hands to sorta grind it back flat....if that's the problem. Of course you might have a pin hole in the cast aluminum somewhere that's causing the leak....
