Maybe this will help a little?
QUOTE=North Beach;n4637714]Re: 75 Starcraft Islander 22 I/O to CC Conversion
JAS, before I paint I need to remove the rub rail or it won't look right. Plus the rails need polishing!! And I do plan on talking to the metal fab guys about whether they can get me pieces that long and at least cut new side pieces with the turn down and return in it. We'll see?
OK, got up this morning and jumped on it again. First thing to do was run a line and trim up the gunwales to final cut. I?m bound by the narrowest area that used to be the front corner of the cabin which measures 5? from the inside edge of the outer rub rail. I decided to cut straight angles to the bow in order to allow for the channel we?re gonna have to fabricate that goes vertical on the inside face of the gunwale. That way we can use straight pieces of sheetmetal and we?re not trying to break any radius stuff. Next I removed all the remaining hardware, lights, rod holders etc. and the two side rub rails and the arrowhead end caps. Good thing I saved the ones off of Old Blue cause these were shot. I climbed up on the roof to get you folks these shots so you can get an idea of how she?s gonna lay out. I?m really starting to get excited!!!!
Next to do was remove the 5 thousand thru transom bolts and screws. Then I removed a few of the outer rub rail thru bolts on each side at the stern and the entire transom cap after I removed the remainder of the vertical gunwale extension in the back. Hooked up the ole JD and a chain and gave it a yank. The transom wood didn?t really want to budge, so I went all around the edge with a big honkin screw driver and the ball peen hammer and once it loosened the entire edge it popped out like butter.
Man that transom was rotted all to crap. Some of it looked like paper mache and you can see all the staining from water leaking. The two transom tie down bolts were rusted away to nothing. I?ll feel a lot better knowing there?s new wood in there.
Next step is in & out power washing and the leak test![/QUOTE]
