Fishermark
- Oct 19, 2003
- 5,617
Here's what your engine will look like when you pull it. You can see what needs to come out. The rear mounting bolts go through either side of the bell housing as pictured here.
We found out that there was a normal camshaft, not even a marine one, installed in the engine.?
There is no such thing as a marine crank shaft and if you hear the machine shop correctly, I would suggest going and picking up your motor and take it to someone else. The crackshaft is the same crankshaft in all other motors of the same size. There are differences in cams, one for a car or a truck. You want a truck cam shaft for low end torque.
Edit: but in your case there should be no difference with the I6 cam
Man I have to read slower, you said camshaft and I read crankshaft, wow my bad
As for the marine and truck thing, the motor used for the I6 are all the same, and a marine cam is a truck cam. Back when these engines were being made Mercruiser bought them straight off the line the GM is using. In later years GM made car and truck motors different and Merc would always buy the truck motor.
You may need a new cam if yours is worn, but someone would have to measure the lift a duration.
Hey Fishermark what say you
AllDodge has it right. There is nothing special about the cam. Truck cam is good. Do go with the metal timing gear over the fiber gear.
The shop didn't talked about changing anything for the timing system other than the gasket. Should I change the gear?
Guys, I'm looking for a camshaft thrust plate, I can't find it anywhere, even in the US. Anybody would have one?
Or maybe the GM part number, I could only find the part # for Pioneer brand.
