I went through this a couple years back with my 302 which uses the same log style manifolds
check out this thread . I put some part numbers and things to help you with your search .
http://forums.iboats.com/forum/engi...outdrives/659072-omc-manifold-conversion-ford
basically if you are looking for new manifolds you will have to convert to center risers . other than that your only options are the log or banana style manifolds , but those havent been made in ages
+1 to REDRIG's approach above. I'm putting a similar set of Barr manifolds on my 1975 351W next month.
Here's the link to the parts:
http://www.iboats.com/Universal-For...aust-Manifold-Exploded-View/dm/view_id.272956
Ayuh,.... Barr or Osco I believe are American products of decent quality,.....
GLM or HGE are chinese, 'n is crappy quality,....
I have a set of GLMs that leaked like a sieve, til I remachined the gasket surfaces,.....
Haven't put a straight edge on it yet. If it is slightly off can a guy hit it with a sanding block?
& noticed they only have 4 mounting bolts to the heads not 8. Is this correct for this conversion?
Wow! I wouldn't think you would get a good seal & would leave more room for warping down the road.
