ThomW
- Aug 8, 2016
- 615
I am just looking for advice on how to check the timing on my 1987 BlackMax 200hp motor. The flywheel has the markings showing the degrees before and after TDC, but I do not see any mark on the flywheel showing where to point timing light. I know I need to attach timing light to the number 1 plug wire, with all plugs removed and turn over motor while fully advanced in neutral. How do I mark the flywheel to know where to shine timing light? Also, how do I actually advance the timing when light is connected? I have only done timing on my I/O, which is simply adjusting the distributor, but have no idea what to do on the outboard to adjust timing. Thanks in advance!
