Hello everyone. Had a slipping clutch Dog on my 1974 50hp Johnson. I was able to get everything apart and got a new old stock clutch dog. Problem I'm having is installing the pin that holds it to the propeller shaft. The pin goes though the shifter control that has ball bearings and a spring. I can't figure out how to push back the spring loaded ball bearing and then push the pin through the gear, shifter and prop shaft. Is there some trick to this. Also when I took it apart the ball bearings and spring were in this order from the clutch dog (pin--ball-spring-ball-ball). The diagram shows (spring-ball-ball-ball). What is the correct order. Thanks.
