itchyfishnv
- Aug 10, 2016
- 59
I did a valve adjustment on my 87 3.0l today and the boat would not start after I did the adjustment. I followed the instructions from mercruiser manual #10. I marked the distributor at one and turned the engine by hand until the rotor pointed to cylinder 1 with the point gap open then made the adjustments, I then moved the engine by hand to point to cylinder 4 and made the adjustments. After I reassembled the ignition it basically started backfiring on me and wouldnt start. I noticed there is another method similar where you bring the engine to TDC then adjust, rotate then make the final adjustments. Any idea what I may have done here?
