Hello everyone, Ok let me cut straight to the problem, I messed up my pump by running it without water for a few minutes, when I took the water pump assembly out it was toasted, so i bought a whole new assembly, put it back-in according to some of the diagram on line, started the engine it took a while before the water came through the "telly tail?"but it wasn't steady flow it was as if it had some air spurting through, when I put it on the water and got it on plane I noticed that only steam was coming out but then when I slow down again I get stream of water coming through but hesitating or trickling out...went back home took it out it seemed like the metal cup inside the housing spun and melted the upper housing ...so I changed it, put everything back together put back on the water and the same story only that the metal cup was still ok...does anyone has any idea or experience about this situation, what would you suggest? what could it be? you guys pulled it out for me few times back ...I am positive you will now too...and thank you very much.
the engine is Mercury 40 hp 1997 4 cyl outboard.
