SHSU
Lieutenant Junior+Starmada Splash Of The Year 2019
- Mar 8, 2017
- 1,758
I Checked the transom carefully. On one side there is some rot, but it is only about an inch from the starboard side. Every other inch is in real good shape.
Probably should look to replace it and get it done with now. Even thought it is only a small portion, once its there it will continue to get worse.
I am looking at the electrical....I got the bilge pump to turn off and on, and the navigation lights only make the fuel gage light up but the nighttime navigation lights will not work. I traced all the wires down and just cant seem to get them to operate. I have not been able to get the livewell pumps to work either. I have traces all the wires and did periodic voltage checks and there is voltage, but just wont turn on. I am not sure what is going on. Do you think it would be best to rewire all the lights and pumps from scratch?
Also this is very strange. I notice that there was a electric connector under the dash that was unplugged, and (in the close up) another connector unplugged near the throttle control. The color wire it was connected to was purple which made me think it was the navigation lights because there is purple wire connected to the lights. So I jumped them with the green wire and the throttle body started beeping. A continuous buzz.... what is that? Any ideas?
Electrical... LOL its always fun
On your lights, I would take a battery and got test them directly at the source. That way you know at least the lights work and you have a wiring issue, same with your pump. Otherwise you will be chasing issues that might not be the real culprit. Personally I would rewire everything so you know exactly where everything goes and you won't have a bunch of wires that you have no idea what they do.
As for the buzzing, that is probably the warning horn for overheating on your engine. Sounds like their must be a short somewhere and it is causing your alarm to go off. If you look at below chart it outlines what colors mean what for Mercury. Purple looks like ignition so it may buzz at you telling you your key is in a start position. Unless of course it is shorted somewhere
(Tried to upload better picture but it won't work... Will try back later)
