Personally withbmy mpi on first spring start up.....
i pull the lanyard kill switch out and with a fully charges battery, crank her over for 5-10 secs at a time. I do this a few times to allow oil to get to the components and build a little oil pressure.
Then re attach. No throttle, listen for fuel pump cutting out and start.
The real value is in how the boat/engine was winterized.
You do know that when you are cranking it, the fuel is being injected into the cylinders, washing away any oil that was on the cylinder walls and rings. You have a dry start at this point.
I thought that when you pull the safety lanyard, that removes power from the ECM and ignition. No wake up power to ECM means no ground for the fuel pumps, no power to ignition means no reference signal to ECM so no ground for the injectors.
How would you get fuel in the cylinders?
You are welcome to do that but never to an engine that I own.
Why ?
I response to my post comment that I would never allow him to abuse an engine of mine by dry cranking it,
Because most of the lifetime wear on an engine happens in the few seconds between the time the starter engages and the time the engine starts and brings up full oil pressure. What you are doing is needlessly prolonging that period. You are not accomplishing anything. You may not be doing a lot of additional damage but you are needlessly wearing out your starter in pursuit of some imaginary wear benefit which doesn't exist.
And mostly because its my engine, my rules.![]()
