rickasbury
Master Chief Petty Officer
- Jul 13, 2011
- 832
This trailer is a train wreck.will start from the beginning and I was very inexperienced with the size boat trailer. Had a couple of boats over the years but never really had trailer problems. This trailer catches me up. I will try to make it short.
bought a Rinker 270 about 4 years ago. Boat is another story so let's stick to the trailer.
Seller said yes, it has electric brakes...well, I figure the trailer was free in the boat deal.
I picked the boat up after a survey about 600 miles from my house. I'm in central Florida, boat was in the panhandle. Was so overwhelmed with the boat I never looked at the trailer. Although I did really tried to be prepared with for the trip home with the boat..had tools, grease gun...extra spares....so, when I got there and opened the resivoir for the hydraulic (not electric) brakes it was a rusted out desert looking mess. Trailer lights did not work, obviously brakes did not...tires were bald and I'm guessing the lugs would never come off (and found out later a grinder would be needed) so what should I do? I'm 600 miles from home, boat is paid for ....I'm heading to Orlando with a 8000 lb boat!
I actually did make it home ok- and as hard as I have worked on this trailer, can't seem to get it straight.
I replaced the resivoir and the electric back up lock out. I replaced the bearings and races..I did rebuild kits for the calipers...new shoes...and I can't seem to work right.
Recently as in a couple of weeks ago...apparently a brake siezed up, cooked the grease out. I think the heat allowed lugs that may not have been tight enough to work off and destroyed the hub and wheel.
So at a cross roads here how do I get this trailer straight.
Trailer is about a 2005 or so? The back up lock out has never worked..I checked the electrical and that is all good. So, not sure if it is the new valve or the brakes just don't work and lock up when I reverse? I put a block in there and that keeps them from locking.
The recent trip where I had the latest problem, I could back up without the block so something was not working with the system...and then I think the one caliper locked and it was total melt down.
So I replaced the hub but the caliper would retract so I just tied it off so I could move the boat. Also, I could not get the block in to the surge slide- tries yanking it forward with the truck, it seems stuck in which maybe explains why the caliper is locked up...just don't know where to start to get this thing straight...I'm fresh water and hardly been able to use the rig with the boat issues which is a whole other issue! If I just drop it off some where might as well buy a new one and that ain't happening? Any straight forward approach to this? Two of the calipers have been replaced...the brakes lines, do they go bad over the years? Do they constrict the fluid when they get old? I rebuilt the calipers, nothing was pitted or rusted...
