Is there a way to exchange the lower unit of the engine to make it like the newer forward facing pentas?
I want to use it to wakesurf but the backwards facing prop seems unsafe.
Nope,.... Those are very, Very different drives,..... Much newer, 'n Nothin' in common with yer's,......
As AD says,... No danger, unless the driver is reversin' the boat at you,.....
Otherwise, the driver would have to run over you with the pointy end of the boat 1st,.....
Btw,...... Welcome Aboard,......![]()
