Thanks Rick. I am replacing the impeller. Already have the full replacement. I will also rebuild the carb. I am curious if I should be doing any particular service to the bell housing, check engine alignment, grease this or that, replace these gaskets or O-Rings....things like that.
I am attaching better pictures.
- Chris
Chris,
When I was at your point in my boat owner training, I started out looking for ways to do all my own maintenance. That meant I spent money I wasn't really wanting to spend right after buying a boat, but in the end saved loads. Alignment bar, parts to build a pressure tester for the outdrive. Other tools and parts as needed. I almost immediately had to do a full bellows job and replace the lower shift cable.
Your next step, and the only one that prevents costlier repairs, is do all the maintenance. When you reassemble the drive, you have to pressure test it to know if any of the seals leak. You do this before pumping it full of oil. I built my pressure tester out of a 16 inch hunk of 1 1/2 PVC for a tank, an end cap, a T, a couple fittings to allow me to mount a air pressure gauge on one T and a brass T with a schrader valve and a small tube with the screw in barbed to 3/8 thread off a drive oil filler pump. There is a sticky on what the good/not good results are. Another on how to build your own tester.
Check alignment every year. Lots of good stuff to get from doing that as noted by Scott.
