757water
- Jul 30, 2019
- 7
Hi I am new here but have been reading this forum every since I bought my boat. I have run into a issue that I cannot figure out. When I first bought the boat, I cleaned the carbs and it ran perfect for about 3 years.The model number is J50PSSLM This problem has been getting worse over the last season, with the outboard stalling at idle in or out of gear. The outboard runs great on the top end so initially I suspected the idle circuit was dirty. I have cleaned the carbs multiple times and am pretty confident they are cleaned.
Compression test is 120 psi on both cylinders and the primer system is functioning properly. I conducted a link and sync with the linkages step by step all the measurements are correct and marks are lined up. The motor will not start in this position. However if I advanced the timer base a few degrees it will start and idle out of gear in the water, Once I place it into gear it will die. I have disconnected the spark advance rod from the throttle bodies and if the butterflies are closed if I advance the timing a few more degrees it will idle in gear, timing light shows TDC at 800 RPM which is in specs if I remember right.
I broke a propeller last season, so I thought my flywheel key had sheared off. I pulled the flywheel this weekend and the key and key way was intact. The hub (trigger magnet) and stator magnets are also in place in the flywheel. The trigger magnet notch is lined up with the white mark painted on the flywheel. The timer base looks damaged (rubbing and cracked plastic) but I tested the resistance and everything checks out. I am at my wits end with this motor and would appreciate any input.
