achris
More fish than mountain goat
- May 19, 2004
- 27,468
Coils are not marine specific. All it needs to be is one that is specified as 'use with external resistor', and have the correct primary resistance. Distributors are very much 'marine specific'...
The standard coil setup on your 165 Mercruiser engine is:- from the key the power goes to a resistance wire (this would take the place of a ballast resistor), then into the positive terminal of the coil (the coil DOES NOT have an internal resistor)... You also have a wire from a terminal on either the starter solenoid or the starter motor itself, straight to the coil positive. That is so when the engine is being cranked, the coil gets full battery voltage (which will have dropped to about 10 volts because of the starter motor load). If the power only went through the ballast wire/resistor during cranking, the voltage at the coil may be too low to produce a healthy enough spark to start the engine.
The resistance wire is about 1.8 to 2Ω, and the coil primary resistance is between 1.1 and 1.5Ω. It does sound like the resistance wire has failed (engine runs while the key is held at START but dies when released to the RUN position), but you can still buy a new one from Merc. The part number is 84-94227A2... That would keep the engine as 'original' as possible. If you wanted to just replace the resistance wire with a ballast resistor, you could do that instead. Just get a normal wire and replace the resistance wire, and run that into the ballast resistor, then the coil positive. Same result. Swapping coils and distributors isn't going to help.
Chris...........
Chris...........
