I went through something similar on mine. The coil was failing, it would start run fine, then start miss stall etc. I’ve seen about 6 failed coils over the decades. This could be various things, getting good info here. Mark the wires on pos and neg both coils. Swap coils and test run with water hooked up to outdrive.
On mine after replacing coil, points, condenser, rotor, cap etc. I thoroughly rebuilt my carb at the same time. It then ran fine.
Your manual shows and others have stated desired voltage to coil both with start and run positions.
You stripped back the resistor wire and re ran and sounds like that did not make any changes.
****Swapping coils make sure they have the same number and indicate if internal or external resistor. Simply performing an ohm test on the coil would show a constant fail but not intermittent. Coils are cheap, I upgraded the distributor to electronic breakerless points.
Also, check your distributor run out, with the power off at the main source, pull the cap. Remove the rotor and test top shaft side to side wiggle. Mine was shot, it had excessive horizontal play which caused impossible point accuracy.
