I troll at idle for hours upon hours at a time. No problems
How long can Motor idle on Muffs or in Water...Safely with out causing damage ?? quick feedback would e appreciated
When the motor is stopped it goes into forward gear.------A spring put it into forward.----When lower unit is in good condition it shift out of forward with ONE TURN of the flywheel.-----------Often the prop will turn with control in neutral.------Use a stick to check.-----I have done it many times with the toe of a work boot !----Check the throttle safety switch on the motor block.----It has and only needs one white wire.
It is right there beside( right side of ) the fuse holder !!
