jasonejasone
- May 4, 2020
- 45
I recently acquired a 1972 Evinrude Sportwin 9.5 HP from a Craigslist ad. Paid $200 without being able to test it... but I had read that these engines are largely considered 'bullet proof' so I went ahead with it.
Well, obviously it won't start or else I wouldn't be here, right?!?!
I've done a lot of work to it already - replaced the spark plugs, cleaned the carb, replaced the kill switch (I thought this was my main issue until I replaced it and nothing changed), and a few more odds and ends.
My current issue is I'm not getting any spark.
I have already cleaned and gapped the points to .020, and inspected the other electrical parts of the ignition system.
I decided to replace the coils, because the ones in there looked quite old, so I figured it wouldn't hurt.
Now I get spark on the lower cylinder, but not the top.
I double-checked that I have a good seat on the plug cord and boot for both cylinders, still had spark only in the lower cylinder.
My question is: Where do I go from here? How can I test / troubleshoot each piece of the ignition system so that I don't buy parts that don't need replacing?
I considered replacing the points (advice online says to do so once per year, is that accurate???), and replacing both the plug wires and connectors... but that brings up another question: which cylinder is associated with which coil? One coil is closer to the throttle handle/transom, the other is closer to the prop side of the engine. Which of those powers the spark to the top cylinder?
Whichever one it is, that's the one I need to troubleshoot since I'm getting spark in the lower cylinder.
Any help or advice would be appreciated! I've been powering my jon boat with an old Sears Gamefisher 3HP motor (which is MUCH simpler and easier to work on) so I am ready to get this boat moving with this new (to me) Sportwin!!
Also - I did not find a thread discussing a similar topic, but if one exists, please feel free to point me in the right direction.
Thanks, all!
Thanks, all!
