Thirsty Endgrain
- May 30, 2020
- 250
Hello, well as per another post down below I've recently purchased a boat with a motor (what could go wrong?), it was stuck in forward (and I couldn't start the engine) and found a frozen shift linkage rod. Currently rebuilding the lower unit now, waiting for seals.
On the the top: I had forced water up the pickup tube with a hose wanting to see if it would clear all of the passages and come down the drain side, but I wasn't sure if the thermostat would block the flow until the engine warmed up (which it won't do 'cause she won't start). No water ever came down the drain side so I assumed either the thermostat blocks flow, or there was a blockage. Got busy with wrenches this morning and well, what thermostat? It's completely MIA. Fun.
So I get even more curious and say what the heck, it's only like 30 bolts with a high likelihood of snapping in the head or block and I've had my coffee so let's do this. 30-ish bolts later (and only 1 snapped in the head! Was expecting worse) and I've got the thermo housing, head cover, and cylinder head off. I don't think they've seen the light of day in 43 years.
Water passages actually didn't seem in too bad of shape for what one might expect, I did see evidence of what *I think* was a melted impeller, picked all that debris out.
Did a cold compression test yesterday since I don't have the option to do a warm one, mind you I only wanted a rough idea.
Bottom - 80
Middle - 70
Top - 72
I think. Should have written it down. I know cold is innaccurate, but I wanted to basically see if any had a big hole in them.
There will be more q's and I appreciate y'alls time, but now that history's done onto my questions:
-Main one - There is some scoring on the top two cylinder walls, both in the same-ish location, intake side. I can feel the ridges with my fingers. I know that's probably.....bad? Pics attached. Bore cylinders and oversized rings? Are those even available? Is the block simply done?
-Is there a chance that scoring won't let the cylinder light a fire? Took about 10-12 chugga chuggas to get to gauge up to those numbers. I know I'd have to do a leak down test to see if the cylinder can hold compression, but I'm wondering if any of you more experienced can advise my best path forward.
-Since everything's apart I want to clean out the head and cover of the salts, is there a favored method of bathing/sonic immersion etc. to accomplish this? Completely new to outboards.
Well that'll get me started I think, thank you!
-Nick
Bottom - 80
Middle - 70
Top - 72
-Nick
