Attempted to test the knock sensors today with a multi meter.
- hooked the positive and negative onto the two prongs inside the connector.
- set multi meter to lowest voltage setting and got a reading
- then tapped on the side of the block with volt meter hooked up and watched for change.
- then tested for continuity between the prongs.
Starboard side ( side that got hotter and blew head gasket) knock sensor had no change In voltage when tapped. It also had continuity.
the port side knock sensor had both a change in voltage when tapped and had no continuity.
I am going to assume that one of these is bad.
Which one ?
I am going to order both sides in hopes of fully solving this problem.
