Lurked some over time but first post.
We got a "free" boat with a Mercury 700 outboard, Serial Number 4830257, 3 cyl, USA made in 1978 I think.
My son and I have been enjoying the project of trying to restore the thing. I picked up a service manual on ebay so have been using that.
The outboard seems to have good compression although I did not measure it. Generally it was in rough shape though. I have done the following things so far:
- New CDI stator, the insulation was really crumbling all the way up to the molded housing on the original
- New CDI rectifier- old was badly rusted and could not get wires off.
- Took carbs off and cleaned. I did not take the welch plugs out but tried to clean the jets as best I could. I think everything is clear and clean. I put new gaskets on. Also had to install a new throttle coupler since the original broke when I took it apart.
- Rebuilt fuel pump
- New fuel lines all the way to the tank and new tank.
- New wiring harness. The old was in bad shape so I bought a bunch of high temp rated primary wire from DelCity.
- New water pump
- Drained gear oil and replaced
With it put back together I checked each spark plug for spark and it seemed to have good spark.
I did not do anything with the timing. We did also install new control cables. These may need some adjusting. With them set so that at full low throttle they are at the throttle and spark stops, the cam only engages the carb throttle lever a little with the control at full throttle.
We tried today to start the engine. The choke seems to work. All we can get it to do is to pop over here and there. It won't really start. I have the idle needle valves set at 1-3/4 turns open as the service manual says.
I will add a few photos later. I need to reduce them in size.
- Rebuilt fuel pump
- New water pump
