shine a light from below (outside the boat) up towards the damaged area and see what it looks like from the same spot inside the boat . . . (take a picture too)![]()
Boy... from the color of that, I wonder if that's all new(ish) damage. Looks awfully dark for damage that's only seen water for a couple of multi-hour outings. I wouldn't expect the substrate to be that mushy from only that limited amount of time in the water. I bet you could take intact flotation foam, hold it under water for a day or two, and it would take on barely any water. That looks concerning to me.
I agree.....very concerning. A proper repair is starting to look like there needs to be some layups done on the inside to properly tie the damaged area in. That keel area should be very thick and strong, not soft and thin. I’d say that needs to be investigated more than what can be seen on the bottom.
When you say the keel should be very thick, how thick is that typically? I marked below where along the keel the damage is. Is the keel typically very thick from the tip of the bow all the way back?
My 1990 Chap was atleast 1/4” to 3/8” glass with 2” wide core wood shaped to the V profile covered in roving. Like the transom, that area should be very strong, certainly not soft.
its really hard to determine what’s going on there, but given the photos, if it were mine, I’d want to open that up topside and repair it bottom up, then fare and gel the bottom. Unless I’m missing something.
What kind of floor are you dealing with? Textured gelcoat? Can you post more pictures so that others can chime in? There are definitely several ways of accomplishing this repair.
In any case, I applaud your difficult decision to end boating for the year. I think you are exercising some good judgement there.
I'd be inclined to find something long and pointy (like an icepick) and try sticking it up into the crack to see how far it will go. If it goes in all the way (e.g., 6") I'd be concerned that section of the hull is badly compromised. If you hit a solid layer of fiberglass BEHIND that damaged area, the problem might be more limited. But getting to that area from the inside is really going to be the best way.
