Rehab SportCraft 222 1983 deep V hull cuddy walkaround
jbcurt00
Thanks JB either I'm missing something or I'm a Dumb Ole Okie.
Click the Reply tab/button here:20201019_183442.jpgbelow each post you want to quote. Keep clicking that tab below each & every post you want to multi-quote.
Once you add your own comments, the hit Post reply below the post window
kcassells
So do I go back to my old kcassells posts? I thought I did do that. Also thank you for more directions and the GIANT cell phone push buttons.
sphelps
For multiple quotes, I scrolled back and clicked Reply @ bottom right of Sam's post.
Then Reply under your post, and then Reply below mine. Each time I clicked a Reply tab at the bottom right of a post, that post was quoted and added into my reply window:
1st Reply click:
2nd reply click added:
3rd reply click added:
Think of it as exactly like multi-quote in the old vB software BUT better because you dont have to scroll back to the top of the page and click the #d Reply button. Xen does that step for you.
You simply scroll to your reply window and drop comments between the multiple quoted text.
Hmmmm I must be missing something also . It won’t let me click “reply “ on multiple post . When you hit reply it automatically puts you in your reply window .. How do you go back to the thread to quote other post to place in the same window . I’m on my iPhone though . That may make difference..
jbcurt00
No idea @ iphone, on my droid it works as I suggested.
Did you try using iphone in landscape AND portrait mode?
There are more options viewable on my droid when used landscape
kcassells
Thanks for your help. Getting too way confusing. I never mentioned an Iphone.
kcassells
Prior shots before the cold. Painting stuff
Steering cables, harness, battery cable pulled to back.
kcassells
Front windows in with 3m process.
sphelps
You got windshield wipers planed ?
Hey, I think your supposed to use distilled water in those batteries not
the KOB .... 😉. Looking good Kc !
kcassells
Thanks Sam. I'm not sure yet. But I have easy access to install. I read about both ways good, bad or necessary. Seems a lot of guys like to use "rain dance" windshield cleaner and keeps the water off. Wash with Dawn soap.
kcassells
It’s gonna be easier to heat with those windows in this winter....
I have a lot of areas on the cover to batten down. Currently get 40 deg. to 80 deg in about 25 minutes. With the engine on the tail of the boat the heater drafts cold air in more than without the motor prior winters. Easy fix. Also use a transport blanket to isolate the cuddy and keep heat to midsection of boat.
Waiting on more electrical crimps to arrive then get onto circuits.
kcassells
Just throwing this out there. Has anyone boated on the C&D canal? Delaware to Chesapeake.
