- Oct 25, 2011
- 25,238
Hmmmm I must be missing something also . It won’t let me click “reply “ on multiple post . When you hit reply it automatically puts you in your reply window .. How do you go back to the thread to quote other post to place in the same window . I’m on my iPhone though . That may make difference..For multiple quotes, I scrolled back and clicked Reply @ bottom right of Sam's post.
Then Reply under your post, and then Reply below mine. Each time I clicked a Reply tab at the bottom right of a post, that post was quoted and added into my reply window:
1st Reply click:
2nd reply click added:
3rd reply click added:
Think of it as exactly like multi-quote in the old vB software BUT better because you dont have to scroll back to the top of the page and click the #d Reply button. Xen does that step for you.
You simply scroll to your reply window and drop comments between the multiple quoted text.
No idea @ iphone, on my droid it works as I suggested.Hmmmm I must be missing something also . It won’t let me click “reply “ on multiple post . When you hit reply it automatically puts you in your reply window .. How do you go back to the thread to quote other post to place in the same window . I’m on my iPhone though . That may make difference..
Thanks for your help. Getting too way confusing. I never mentioned an Iphone.No idea @ iphone, on my droid it works as I suggested.
Did you try using iphone in landscape AND portrait mode?
There are more options viewable on my droid when used landscape
Kc the iPhone was referring to my post and the trouble with multiple quotes .Thanks for your help. Getting too way confusing. I never mentioned an Iphone.
Thanks Sam. I'm not sure yet. But I have easy access to install. I read about both ways good, bad or necessary. Seems a lot of guys like to use "rain dance" windshield cleaner and keeps the water off. Wash with Dawn soap.You got windshield wipers planed ?
Hey, I think your supposed to use distilled water in those batteries not
the KOB ..... Looking good Kc !
I have a lot of areas on the cover to batten down. Currently get 40 deg. to 80 deg in about 25 minutes. With the engine on the tail of the boat the heater drafts cold air in more than without the motor prior winters. Easy fix. Also use a transport blanket to isolate the cuddy and keep heat to midsection of boat.It’s gonna be easier to heat with those windows in this winter....
Mike, Great to hear from you. The bottom line is to just take care of yourself.Glad to see you’re back at it. I’m still not 100% from the Heart surgery but getting better each day
